    Apr 2010
    11
    Default floor installation
    Do you install a floating or other flooring left to right or start in the middle and travel to either end.
    Oct 2010
    Chicago
    26
    Default Re: floor installation
    Hey Banktpg1,
    When installing wood or laminate floors you normally start in the corner against the longest wall. You also lay the flooring in the direction of the main light source, or longways across the floor. Hope this helps. Here is a link on basic install instructions.
    Oct 2010
    Chicago
    26
    1,522
    floating floors and all wood types of floors are started at the corner and installed teh length of the room typically, the only thing to take into consideration is to check the opposite walls for parrallel so you dont end up with wedge shaped peices at the closing wall
    tile is layed out from wall to wall but the layout typically starts at the center of teh room, you find center then base the layout off of this, either making for a more aesthetically correct floor or so you have to make the least amount of cuts
    Both are good answers, but let me add this:
    1. When laying down wood, laminate or tile, leave 1/4" space to the walls. Base molding will cover the gap later.
    2. Be prepared: for tile floors you will have many cuts, there is really no way around it. Most cuts can be done with a hand tile cutter, but complicated cuts (around door jambs) must be done with a tile saw (like MK).
    Depends on the intricacy of the layout, such as an open floor plan with many rooms connected by hallway. When I installed mine I laid out from the centerline of the hallway that started at the front door and went through to the back of the house. From there I laid it both directions to fill the kitchen, dining room and a perpendicular hallway terminating at a 1/2 bath.
    The flooring I used had a standard T&G edge, so laying in either direction was a piece of cake. With the advent of today's "click-n-go" flooring, one must start at the wall and work across the room because the flooring really only wants to go together in a specific manner, work backwards from that and the job becomes impossible. The cure here, is to lay out from the center-line of your sight line and snap a reference line. Now measure an equal distance to the starting wall from each end of the line and snap a second line near the wall. This becomes your starting line to lay the floor from one direction.
    As DJ said, leave at least 1/4" gap (read the packaging for manufacturer's recommendation ) along all walls and stationary objects (cabinets, door jambs, etc. ). This is to allow for expansion and contraction of the flooring material. Door jambs can be under cut so that the flooring slides under the jamb and trim, but you still need the gap to the wall and framing behind the jamb and trim.
