Results 1 to 10 of 15
Thread: Roofing Advice
    Colorado
    49
    Default Roofing Advice
    Hoping this is the best place to ask these questions. I'm asking for a friend of mine who still has dial-up and can't deal with how long things take to research with dial-up.
    She'll be getting a new roof (compliments of hail and her insurance company) and wants to be able to ask the right questions of the roofing contractors and make the most of this opportunity.
    So here goes:
    1-Traditional shingles vs architectural shingles? She wants to know about the durability and the cost between the two.
    2-Frost shield between house and 3-season porch, yes or no?
    3-Ridge cap vs. wind turbines? Just pros and cons, I guess. She is getting different info from what I've researched for her and the roofing contractors she has talked to.
    4-Is it easy for roofers to recycle old shingles all over the country? Do they recyle and if so, into what?
    5-Solar panels in shingles? Is this the wave of the future and to be considered for a replacement now?
    6-Price difference of a steel roof vs. shingle? Any down sides to steel replacement on a low pitched roof?
    So, thanks in advance for what I know will be great advice and input, that I will pass on to her. I need a new roof too, but that ain't gonna happen until I get baseball-size hail, too!
    7,602
    Default Re: Roofing Advice
    Let me start with a question, where is the house located? It makes a difference in the products and methods used.
    Quote Originally Posted by mtngigi View Post
    So here goes:
    I assume you're referring to 3-tab shingles as "traditional". Many municipalities have banned their use for reroofing purposes - repairs yes. The preference is to use architectural that mimics the look of a shake roof, which is far more aesthetic. As for durability, the architectural wins, hands down. They're essentially twice as thick, making them heavier duty. I believe you can get up to a 50 year warranty on architectural shingles.
    Depends on your climate zone.
    Again, depends on your climate zone. Ridge vents are more aesthetic, but if you're prone to snow loads, then go with turbines that can be covered in the winter to keep out thawing snow and ice.
    Roofing materials can be recycled, but it still seems kind of hit and miss where it's being done. The last roof I did, the drop point did not have a reclamation area for asphalt shingles, only wood. I do not know what kinds of things are made from recycled asphalt roofing.
    I would recommend caution with these products, do plenty of research, and make sure that your application is ideally suited for such a thing. I'm all for solar, but am extremely leery of incorporating it into the roofing itself due to durability and longevity issues. I'm not saying these products are bad, just do your homework and make sure it's will work for you - they're also expensive.
    How low of pitch? Asphalt shingles can be installed to as low as a 2/12 pitch, though not recommended in snow load conditions. Steel would be the better choice from what I know of it. Steel is expensive, but has little to no maintenance issues when properly installed.
    Colorado
    49
    ***, thanks for all that.
    Actually, it's pretty much due south of St. Louis ...
    She's in Missouri - little town southeast of St. Louis. I'm going to send her all your answers in an email.
    Thanks again for taking the time.
    To add to Sprucey's excellent responce ( as usual ) ---
    turbine vents will require maintenance at some time since there is a * bearing* ( of sort ) that can wear out.
    Personally, a ridge vent is a better choice and there is no maintenance.
    3,123
    What they said plus;
    3- ridge venting with continuous soffit venting works best with no maintenance issues
    7,602
    Thank you for the vote of confidence, my only concern with a ridge vent in a snow situation (doesn't St Louis get snow? ) is that during melt it will allow water in through the ridge venting. Now, I will stipulate that I've never lived in a snow load region, so this is a guess on my part, but an educated one based on my knowledge of typical ridge venting systems, particularly those obscured by ridge shingling.
    Heck, I never worried about condensation in bathroom venting until meeting you crazy folks!
    There really isn't a concern with melt water entering a ridge vent. The ridge vent is at the highest point of the roof --- the peak --- gravity dictates the water flows down the slope of the roof away from the ridge vent.
    Besides , the amount of snow they would get is a mere pittance of what we get here and we don't have issues with ridge vents.
    3,123
    Its not just snow melt but rain, and wind driven rain, all of which ridge vents are designed to handle.
    If in doubt, check the attics of several homes with ridge vents. You'll see perfectly dry plywood. I have it on my home and we have had several direct hurricanes with 100mph winds.
    7,602
    Then I shall defer to you fine furry folks that live in the white stuff.
    That's one of the advantages of being a flat lander, we don't have to worry about such things.
    Colorado
    49
    Thanks everyone for your all your input, and I've passed it along to my friend. She made this comment to me about pitch:
    "Well, pitch # is info I just don't know about. But this house is 45+ years old, and has had shingles since it was first built, that's all the info I can offer. I'm beginning to think the architectural shingles may be the way to go."
    I think a big concern she has is making sure she ends up with a reputable/reliable roofer who will do a good job and not rip her off or take advantage, which we all know can happen.
    Is there any way to get recommendations from this community as to local contractors in a specific area ... other than obvious things like the BBB?
