    May 2011
    Default Walls Are Moving
    I own a house originally built as a summer camp in the early 1940's. The walls have bowed out over the years and I have done my best to put supports in the attic (eg. collar ties,etc) but after some very severe winters, the corners of the walls still crack and continue to travel. Someone has mentioned the use of cables in order to tie the roof plates together to stop the movement.
    I was hoping for some advice or the name of someone who could inspect the problem to give me the correct solution.
    Thank you in advance for your time.
    Sep 2009
    florida
    598
    Default Re: Walls Are Moving
    Quote Originally Posted by rforesteire View Post
    Is the roof a Gable. If it is I cant see the end walls pushing out with the studs under the Gable roof rafter. I would think if the house was built in the 1940's the Gable is sheathed with 1x material.
    Gizmo
    Hidden Content
    Hidden Content
    Unfortunately no one can really offer specific recommendations over the internet --- sight unseen -- cables or rods with turnbuckles -- perhaps.
    However, if there are ceiling joists and providing they are properly fastened to the exterior wall top plates these act to keep the walls from pushing out.
    There may also be foundation issues causing the walls to bow out.
    A structural engineer would be a good choice to evaluate the structure and make appropriate recommendations.
    2,000
    Ditto the recommendation for an engineer to evaluate the situation and possible fixes.
    A good & experienced contractor could be a big help, but I'd probably start with the engineer.
    May 2011
    Thanks guys. Any suggestions for a Structural Engineer in the Billerica Area?
