Results 1 to 7 of 7
    May 2011
    Default Ventless Bathroom Fan
    Are these any good? We live in an old house, over 100 years old. It would be a significant job to install a vent and I'm looking for a relatively non-invasive 'fix'.
    Jan 2009
    Needham, MA
    559
    Default Re: Ventless Bathroom Fan
    installing a ventless fan in a bathroom is 100% useless.
    3,120
    How about a fan-less vent?
    also known as a window....
    7,592
    The point of the fan is to exhaust moisture and odors out of the space. Unless it's vented outside, all you'll be doing is recirculating it, which is pointless. Do the extra work and install a vent to the exterior. Make sure you install it properly for your local to prevent icing or water condensing and running back out of the fan and dripping on the floor.
    93
    Where exactly is the bathroom located in the home and what is beyond the walls, ceiling and floor?
    Mar 2011
    16
    Ventless bathroom fan is useless. Plan for fan with vent. Vent location as well as fan location is important. At my job place we have poorly fitted fan at the inner part of the vent. It poorly serves the purpose. We're planning to change it.
    Hope my experience will help you.
    Sohel
    7,343
    Having a ventless fan is as bad as having no fan.
    If you want to install a fan in your bath, it must meet today's code, that means it must have a vent to the outside.
    But the best vent is of course a window.
