    Apr 2011
    Default bahroom light fixture
    what do i check after the circuitbreaker ad th switch-how d i check the wires to the light fixture
    7,970
    Default Re: bahroom light fixture
    What is the problem that you're experiencing, including the symptoms leading up to the problem?
    42
    Bonus points for proper spelling .
    7,762
    It's hard to guess what your question is...
    If your light fixture doesn't turn on, is this light fixture the only one not to come on?
    If yes, you may have a bad on-off switch, replace it.
    If no, you may have a bad breaker, replace it.
    If problem is not solved, you may have a wiring issue.
