    Oct 2008
    Question need to remove garage door adhesive
    hi we put vinyl strips under our garage doors to keep the water out.they were put down with adhevise on the concrete and now we need to remove it. we had new doors put in and need to move the strips any suggestions would be helpful thanks
    Default Re: need to remove garage door adhesive
    Scraping with a sharp razor (normally used for floor tile removal) should get the vast bulk up. After that a solvent such as a paint stripper (be careful) or goof-off should dissolve any remaining bits.
