    Apr 2011
    Default Texture drywall to match plaster
    Is there a painting technique that i can use to make drywalled walls look like plastered walls. We are redoing some walls and adding some walls in our new home and all of the walls are plaster, so some rooms will have plaster and drywall in them. How can i make them all look alike?
    7,230
    Default Re: Texture drywall to match plaster
    A drywall professional should be able to get a close match for you, no matter what type of wall or texture you've got. The technique used depends on the desired effect you're looking for.
