Thread: wiring Problem
    Apr 2011
    Default wiring Problem
    How do I trace wiring from two different ceiling fixture to the light switch and service panel in my garage? Is there a device that I can rent/purchase like the one the telephone serviceman used to trace the phone wiring?
    Thank You!
    Feb 2011
    Brown county, Ohio
    52
    Default Re: wiring Problem
    There are many different types of circuit tracers. I looked at BBS(big box stores) websites, and they have many around $45. I hope it works well for you. Although there is always the old practice (and probally frowned upon practice) of just grounding out the hot, and the tripped breaker is the one you are looking for. Wouldnt suggest that though. Good luck and be safe buddy.
    Apr 2011
    6
    Are you trying to figure which breaker controls the fixtures? couldn't you just through the switches and see which one turns off the lights?
    1,901
    Quote Originally Posted by ajbest View Post
    That works fine and dandy until you kill the power to Grandpa's life support system
    Whenever I am turning off a circuit to work on it, I will connect a lamp or something and make sure it works. Then, with someone (and walkie talkies if needed) watching, I will turn off breakers until they say it's off. Then I turn it on again and they say it's on... then off again and they say it off. The reason I do it twice is to make absolutely sure there wasn't something else strange happening at the same time.
    Fencepost is correct.
    However, if you are working in a vacant house and you have no helpers to report to you that you hit the right breaker, you can turn the main off...
