Thread: Sink advise
    Apr 2011
    Warsaw, IN
    Default Sink advise
    I have a double kitchen sink. When both drains are open it drains quite well. If one side is stopped for dishwater the other side drains very slowly. The water goes down a small bit and then bubbles come up through the drain and the level drops a bit. then repeats, until drained. Pulling the plug on the other side allows both sides to drain normally. What's wrong?
    Mar 2011
    16
    Default Re: Sink advise
    It's the venting issue. Snake the kitchen roof vent...
    Apr 2011
    11
    From what you are describing it seems like a venting issue. Picture a milk jug full of water, if you tip it upside down the jug will start to suck in and pull air in from the bottom, until you puncture a hole on the top allowing air to draw in. A vent works the same way, it allows the water to flow down the drain without having to suck air in from the sink.
    I would suggest installing a vent, or getting it unclogged if you already have one.
    Good Luck!!
    Apr 2011
    Warsaw, IN
    Thanks to you both. I'll have to inspect the plumbing and see if it is vented.
