    Apr 2011
    Default Hydranic Heating- Using a water heater
    Greetings, I want to find out a couple of things. I live in the central valley of california(it does not get that cold here), my house is around 1200 square feet. I already have a pellet stove and wood stove in different rooms of the house. I was wondering if a hot water heater would provide enough heat for 3-4 wall radiators(one being a towel radiator)? I am not looking to heat the whole house simply take the bite out of the air. I was thinking to make the heating system a closed one(we already have a hot water system). Also is adding anti freeze to the water a good idea? We are out in the country so LP is our form of gas. Also is there a good and detailed book(with plenty of diagrams) on the subject.
    206
    Default Re: Hydranic Heating- Using a water heater
    First of all, you should look at house heating as a CENTRAL SYSTEM, capable of heating the whole house, rather than a room at a time.
    Given the relatively small area of the house & perhaps a relatively mild climate of Calif., you might be better off with a mini-split AC/Heater that heats & cools, rather than a dedicated centralized heating system.
    Heating & cooling a structure are always calculated according to the btu's (british thermal units, heat molecules) that are entering (cooling) or leaving (heating) the structure each hour.
    A home the size you have perhaps has a heat loss of approx. 35 to 40,000 btu/hour; this would have to be measured by the heating/cooling tech via a "heat loss calculation" when you call to have come over & give an estimate of the type & price of the equipment to be put in.
    The general idea is to heat or cool the entire home using automatic equipment that requires very little, if any, routine maintenance; this will increase comfort & keep the utility costs down; it will also be more appealing to prospective house buyers when it comes time to sell your house.
    Aside from a mini-split, another low-cost option is a dedicated hydronic cast iron boiler that has a capacity of 40k to 50k/ btu/hr with 3/4" plastic PEX piping going to radiators (cast iron or stainless steel), or more commonly, fin-tubed copper baseboard.
    Consult the Yellow Pages under "Heating Contractors" & call to have several of them come over the house to give their suggestions as to the type of equipment, & price range.
    You might consult the public library in your area for books on heating/cooling (HVAC); most libraries generally have 10 to 20 of these books that will give you a good background.
    What are the summer heat temps in your area, as well as the winter cold temps???
    Jun 2010
    93
    Default It could be done
    If you planned on using a standard gas water heater you could do it. I don't recommend a water heater as a heating applicance as it is not rated for the job.
    You must sign the panel rads utilizing the water temp correction factors for btu output.
