    Oct 2008
    10
    Default sealing exterior water line entrance
    How should I seal the space around the copper water line as it enters the house? The home was built in 1917; I do not know what year water was brought into the home. I recently discovered that that is where water is entering my home on rainy days.
    1,522
    Default Re: sealing exterior water line entrance
    hydraulic cement is your best bet, it will set up even if submerged under water and it expands into the joint as it cures, other wise use a polybutyl caulking
    7,341
    Another great product is called Thoroseal, which is a waterproff cement. It will stop the water.
    Oct 2008
    10
    It has also been suggested that I cut the copper pipe in order to encase it in PVC - is that necessary?
