Results 1 to 10 of 18
    Question 120 volt power sometimes
    I installed a 120v receptacle in my pool area off a dedicated GFI breaker.
    When I plug in a 2 prong drop light it turns on.
    When I plug in a 3 prong submersible pump to pump off my pool cover - nothing. It is not tripping the breaker. I plug in the pump in my garage - OK.
    Any ideas?
    Jan 2011
    Columbiana, Alabama
    623
    Default Re: 120 volt power sometimes
    Rg when you plug the pump into a garage receptacle it is probably in a horizontal position. When used on the pool cover it's probably vertical.
    I suspect the pump has a built-in float switch which is cutting off electricity because it thinks the pump is dry.
    Good Luck from Wilsonville, Alabama
    Maurice Turgeon, http://thesemi-retiredelectrician.com
    Thanks, Maurice.
    I think I'll try a couple of other three prong appliances on this receptacle to see what happens.
    OK
    This gets more wierd.
    Following Maurice's suggestion I tried the pump at both the pool and garage receptacles, by holding the pump vertical and horizontal. No change. It obviously does not have a "float switch".
    Then I thought I probably have a "load" issue. I checked the pump and it draws 12 amps. I found a circular saw that draws 12.8 amps and plugged it into the pool receptacle. Worked fine!
    I'm still at a loss.
    Any advice would help.
    Feb 2011
    Brown county, Ohio
    52
    Just courious about this. Do you have one of those $4 plug testers that have the three lights on it? It tells you if all the connections are ok. I would like to see you plug one of those in there and see what happens. Thanks. Be safe and good luck
    5,558
    Most motors have a small amount of ground leakage, my guess is that your submersible pump exceeds that allowed by the GFCI.
    Feb 2011
    Brown county, Ohio
    52
    Also does your gfci trip when you hit the test button, basiclly where i am going with this is polarity. I believe it is possiable with your pump obviously being a motor if there is a problem with your hot and neutral reversed. Good luck and be safe greg
