Thread: Lawn Drainage
    Jun 2010
    Chelmsford, Mass
    10
    Default Lawn Drainage
    I have an area of my front lawn (really yard as grass doesn't grow there very well) that is slightly depressed and when it rain, this area collects water and forms a puddle for a couple of days until it drains. I could add more loam but I'm not sure if I should prepare the ground somehow prior to adding loam. I have heard I should roto-till the area and till in some peat moss. Is that the best solution?
    85
    Default Re: Lawn Drainage
    Yes, doing a roto-till and adding some peat moss to the present soil sounds like it would be do the trick---I would also add a few bags of coarse sand to allow the soil more drainage.
    While you're at it, installing a ten to 20 foot 4" perforated plastic drain pipe at a slight pitch toward the sidewalk/street, or lower point from the lawn would get any water out of there that may be collecting at a lower impervious layer---you may have a layer of hardpan or clay under the section that is preventing water drainage.
    If the sidewalk/street or other adjacent point is not at a lower point than the lawn, a small drywell/french drain would be another option.
    It sounds like a lot of work & expense, but it's really not, and I'm sure your work will be well-rewarded.
    Google "soggy yard" for sites that deal with water accumulation on lawns and laying a pitched drain, and drywall/french drain construction.
    http://www.freeplants.com/free-artic...ding-water.htm
