    Apr 2011
    Default dedicated circuit for fridge?
    Just purchased a new to me 60s rancher and the fridge is running off a counter top outlet. Should it be on a dedicated circuit?
    Default Re: dedicated circuit for fridge?
    You betcha ................
    3,201
    Does it have to be? no, Should it - yes.
    When the fridge starts to cycle on it draws a fairly high amp load which can easily make lights dim and do not-so-nice things to sensitive electronics.
    Besides, dedicated outlets for major appliances are a very nice touch. If you have the opportunity to do so, yes, yes, yes.
    6,063
    Another point, if any of the wiring for the kitchen has been brought up to code, the counter-top outlets are GFCI protected. A refrigerator out let does not require GCFI protection, and you don't want a tripped GFCI to cause your refrigerator to be shut off when full of food.
    Columbiana, Alabama
    843
    All good answers and to echo Jack, refrigerators and freezers in unfinished basements must now be GFCI protected. Bad idea IMO, especially if they are hand-me-downs that have high leakage to ground.
    Good luck from Wilsonville, Alabama
    Maurice Turgeon http://thesemi-retiredelectrician.com
    Food prices are at all time high. Protect your investment, and have your fridge on a dedicated circuit.
