Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Backyard Bridge
  1. #11
    Default Re: Backyard Bridge
    You're welcome.
  2. #12
    The deep South
    459
    I have a bridge that spans a creek in my backyard . Normaly there is just a trickle of water flowing . During periods of hard rain , the water can rise well over the bridge with a VERY strong current . The bridge supports are sunk deep in the ground
    to prevent it being washed away . Something to consider .
  3. #13
    6
    djohns:
    what type of bridge did you build? are the bridge supports concreted into the ground? any chance you could snap and attach a pic?
    I was thinking about maybe making a bridge like you would see over a river, two supports on either side, cable high and low, treads supported on the bottom cable (even though i am not sure how to actually afix the treads to the bottom support) -
    any ideas on where to look?
  4. #14
    6
    fyi:
    found this website with links to several sets of plans for different bridges - http://www.backyardspaces.com/bridge.html
    will figure it out.
    thanks
    stuckinnj
  5. #15
    1,904
    Check out the Lava Canyon Suspension Bridge. Might give you some ideas.
