    Apr 2011
    Question Isolator getting hot
    I have installed a capacitor bank of 175 kva to correct the power factor.I have connected the load of 260 amps(for Capacitor bank) from a 400amps isolator, but now that isolator is getting hot. here the ambient temp. is 38 now. next couple of months it will be 55 degrees. I don't know why the isolator is getting hot? pls help me.
    Default Re: Isolator getting hot
    Quote Originally Posted by rajrama34 View Post
    Way beyond the scope of the home DIY stuff on this forum --- call in a professional electrician.
    Columbiana, Alabama
    843
    Although the 400A switch should handle the 260A load if the switch is in direct sunlight or near other heat sources you may want to install a sunshade and paint the box a light color.
    Also, using a digital IR thermometer check the temperature of the components in the isolator assembly, particularly the terminations (may need to be re-torqued)and switch mechanism.
    If need be, install a fan or vortex cooler (if you have 100 PSI air available) to drop the temperature.
    Good luck from Wilsonville, Alabama
    Maurice Turgeon [URL="http://thesemi-retiredelectrician.com"]http://thesemi-retiredelectrician.com[/URL
