    Default What is this thorn bush?
    We have these thorn bushes around the bases of most of our trees. We are wondering what it is and how to kill it without killing the trees and lawn around it?
Name:	random around the house 018.jpg
ID:	2304   Click image for larger version.
Name:	random around the house 016.jpg
    5
    Default Re: What is this thorn bush?
    In order to get rid of this thorn bush you have to cut/eliminate from it's roots.
    1,627
    Can you post a picture taken further back, showing more of the bush (and if possible, the leaves)? It looks like a Himalaya blackberry, but it's hard to tell by just looking at the canes. You can also bring a sample to your county Extension office (usually run by your state university) for identification and advice.
    If that's what it is, there are two ways to get rid of them. The most environmentally friendly is to grub them out by the roots (you must remove the roots) but that will be a LOT of hard work.
    You can also use an herbicide that is listed for the species of plant you want to remove and that is absorbed by the foliage, being careful not to get any on desirable plants (your trees). Crossbow is one such herbicide, but may require application by someone who is a certified applicator.
    Even after application of herbicide, you may find that some of the plants will regrow from the roots. These root wads must be completely removed; if possible, destroy them by burning. Himalaya blackberry is a particularly tenacious, invasive species not native to the United States.
