    Apr 2011
    Default removing paint stain
    I was painting furniture on a concrete porch with a sheet as a dropcloth and some paint bled through the cloth onto the concrete floor. It was latex paint so I tried to remove it with soap and water-no luck-then paint remover-still wasn't effective. Any other thoughts on how to remove it?
    1,769
    Default Re: removing paint stain
    Try scrubbing with an old fashioned scrub brush with very hot water and TSP. Rinse with a power washer. You will probably end up with a clean spot on your concrete. A general power washing of the entire concrete will lessen the light spot. "Behr's 2 in 1Deck Cleaner" will also aid in getting your concrete looking like new. It is a mild solution of oxylic acid.
    Apr 2011
    Thanks so much. Will try.
    Apr 2011
    Very good initiative. But I have no idea about it..
    Apr 2011
    If it's a latex stain... try using denatured alcohol. The denatured alcohol will lift the latex off the surface without staining the concrete or leaving any residue.
    Apr 2011
    11
    Keep us updated on how it turns out! I'm contemplating a similar project...
