    Apr 2011
    Default weather/water damaged floor
    Need advice on how to embark on fixing rain/weather damaged floor, bottom right floor under french door leading to backyard. Pulled up carpet around area and noticed rotten wood on right side molding/door frame leading deeper into floor. Any ideas how & where to start?
    Default Re: weather/water damaged floor
    What kind of substrate is below the flooring? Wood? Concrete?
    Where is the rotten wood exactly?
    Apr 2011
    Thank you for the reply. Wood substrate is under the floor. Location of rotten wood is right underneath the door jam.
    Advice is greatly appreciated. Novice but always willing to learn and fix things independently.
