Results 1 to 8 of 8
    Apr 2011
    Question Victorian Wood Exterior Door-how to repair wood rot
    I have a beautiful Victorian Wood Screen Door on the outside of my inner door....It's 10 years old, has been painted 3 times, but am just noticing an area that looks like it's rotting....anyone have any suggestions on what to do before I repaint it ? thanks, Linda
    Jan 2009
    Needham, MA
    559
    Default Re: Victorian Wood Exterior Door-how to repair wood rot
    minwax makes a wood epoxy that you can use to fill the roten area. you just have to sc**** it down to solid bare wood before you use it. put it on a little thinker than the wood then sand it down to match. it will be stronger and last longer than the wood and it can be painted after.
    Sep 2008
    Fargo, ND
    144
    A 10yr.-old Victorian?! j/k!
    Yes, definitely remove all "soft" material.
    Then the important part...
    Make sure you use a "Wood-Petrifier" b4 the Epoxy-filler goes on.
    It's a separate product that hardens-off the wood to eliminate further deterioration.
    Painted 3 times in 10 yrs.?!??!
    * That seems a little more frequent than it should be.
    * What part of door is affected?
    * What kinds of prep and paint have been used?! (EXACTLY)
    * What side of house is it?
    * Direct SUN/weather-exposure, or sheltered by a porch?
    Faron
    Apr 2011
    The wood door is exposed to the elements, not covered by a porch. I used exterior Para Paint...best they sell. It's on the east side of the house, and I sand it smooth before painting.
    6,017
    Epoxy products will work to do repairs. I have to ask, when you paint the door do you do all 6 sides especially the bottom?
    Sep 2009
    florida
    598
    Google "Git Rot". The product is great for wood boats..
    Gizmo
    Hidden Content
    Hidden Content
    Apr 2011
    Yes Mr. McDaniel, I do paint all 6 sides, including the bottom.
    thanks for the tips
    27
    I concur with the Minwax wood hardener and epoxy repair - I've used it on rotted windowsill and trim with great results.
    If the deterioration is in a trim or otherwise distinct area of the door, purchasing a new component part may also be a good option. Using a non-wood product isn't 'genuine', but it won't rot, either!
