Thread: kitchen sink
    Apr 2011
    Default kitchen sink
    i am having a problem with my kitchen sink. the problem is when i do the dishes i fill one side with the soapy water. when i am done with the dishes and i drain the sink the water goes right to the other side of the sink then begins to drain out. what can i do to fix this issue
    Apr 2011
    Smile Re: kitchen sink
    Hi, I think you have the drain pipe on the wrong side.
    If you have a sink with a main and a small second sink then the main sink should have the drain straight down and the second sind is on the elbow. The other problem cold be the 'S' bend is not fitted correctly or is too high.
    Hope this helps.
    South*East
    1,257
    Default Re: kitchen sink
    You have a partial stoppage. You can try cleaning the trap, if that fails then the stoppage is further down the line and it may require a snake to clear it.
    John
    You have stoppage past the point where the two sink drains meet.
    John is correct. Cleaning and/or snaking will solve the problem.
    Apr 2011
    11
    Sounds like a slow drain, snaking it may resolve this issue.
    Good Luck!!
