Results 1 to 7 of 7
    Apr 2011
    7
    Default running new drain
    what is the proper way to run a 2" drain perpendicular to floor joists?
    can i laminate 3/4" plywood to joists then drill 2 1/2" holes in joists?
    Sep 2009
    florida
    598
    Default Re: running new drain
    Quote Originally Posted by rephil34 View Post
    You could do it that way,make sure you pitch the pipe.
    You could use these also.
    http://www.google.com/products/catal...d=0CFYQ8gIwAA#
    Gizmo
    Hidden Content
    Hidden Content
    What kind and size of joists do you have?
    To drill out 2.5" requires a certain joist size. Make sure you know the code.
    Sep 2011
    Michigan
    7
    Pitch is 1/8" per foot. Less and solids settle out. More and your pipe will scour out the bottom eventually.
    Jul 2009
    Northeast
    661
    I believe pitch is 1/4 per foot in MA., don't know about any other State.
    Sep 2009
    florida
    598
    [QUOTE=Sten;251812]I believe pitch is 1/4 per foot in MA., don't know about any other State.[/QUOTE
    I think 1/4" per foot is standard in a Hand Dug Out House also.
    Gizmo
    Hidden Content
    Hidden Content
    Slope required in CA is 1/4" per foot as well.
