    Apr 2011
    Default trim for crawl space door
    I have a access door to crawl space and trying to trim out to hide the piano hinge
    1,522
    Default Re: trim for crawl space door
    how did you install the hinge, is it screwed to the edge of the door and the edge of the jamb or attached the face. either way you will see it, just the first way you will see less
    Apr 2011
    I hinged it inside jam and backside of door panel, have 3/4" gap allowing for door to open outward. I tried to upload a picture. Will not accept
    crawl space door 001.JPG:
    This is not a valid image file.
    1,522
    i build a ton of hatches similar but i install the hinge to the edge of the door and to the face of the jamb, also the door gets cut about 3/16" smaller than the jamb opening not 3/4".
    if the crawlspace is supposed to be attic space you cant get a good seal if there is weather stripping installed
