    Apr 2011
    Default Alternative for MDO or Marine Grade Plywood
    My son is building a shed for a local school as an Eagle Scout Service Project and we are looking for a inexpensive way to have a smooth surface on the back to turn into a chalk board. Looking at MDO or Marine Grade plywoods and finding them hard to get and extremly expensive. Any thoughts on how we can make this work with out breaking the budget? Thank you
    Sep 2009
    florida
    598
    Default Re: Alternative for MDO or Marine Grade Plywood
    What's going on the outside of the shed for the finish, plywood,siding,,,????
    Are you going to use chalk board paint on the inside ???
    http://www.amazon.com/Rustoleum-NCF-.../dp/B0006BAEMM
    Gizmo
    Hidden Content
    Hidden Content
    Apr 2011
    I am looking to do the outside in a smooth finish plywood sheet, no seams. it will be completely painted but the back outside will be with the chalkboard paint.
    Thank you
    1,203
    I thought chalkboard paint was an interior finish.
    Casey
    Apr 2011
    Casey - There is an exterior product at sydneyharbourpaintstore . com (sorry i guess i cant post links yet) they have a location in NY. I have not used it before so will find out how it holds up.
    Sep 2009
    florida
    598
    Here ya go Tim I will help ya out until you can add links.
    It's a Porter Paints product
    Spec Sheet
    http://www.sydneyharbourpaints.com/m...cification.pdf
    http://www.sydneyharbourpaints.com/p...alkboard-paint
    Gizmo
    Hidden Content
    Hidden Content
