    Apr 2011
    Exclamation Horsehair plaster on chimney -safe?
    I am planning to have a wood stove installed into an old chimney. It will have a new insulated flue liner, backer board behind the stove, etc. but I removed the panelling that covers the chimney now because I was going to remove the panels to leave the chimney exposed and discovered that it is covered with ugly old horsehair plaster. I don't know if the chimney was operated like this or how long it has been there. What I want to know, before I build a hearth for the stove, is if this will be safe in terms of fire resistance and possible fumes? Thank you.
    Aug 2009
    Ladson,SC
    192
    Default Re: Horsehair plaster on chimney -safe?
    As for fire rating the plaster will not burn and would be rated the same as the substrate it is applied to.
    As for Fumes there would be none from the plaster.
    In high heat the lime will return to a powder, sand will melt and the hair will burn.
    If this plaster has any Gypsum content it may have some rating?
    1,203
    I have seen such plastered chimneys survive house fires intact. The quantity of animal hair used in lime plaster scratchcoat/browncoat is inconsequential in terms of incurring a fire hazard.
    Nor does plaster give off fumes of any kind. It is a sanitary material, unlike drywall or wood.
    Casey
    Sep 2009
    florida
    598
    Hmmm....Ive never heard of Horse Hair plaster so I googled it. It looks like some of it has Asbestos mixed in with it.
    You might want to research it some.....
    Good Luck
    Gizmo
    Hidden Content
    Hidden Content
    Apr 2011
    Thank you very much for the insight. I think I will remove the "Wood" panels and install cement board and tiles over the chimney just for aesthetic reasons and in an abundance of caution.
    1,203
    Only three things must be in lime plaster: hydrated lime, sand, and water; animal fibers were added to minimize drying cracks and help the lath keys stay strong; anything else added, like asbestos, was just an adulteration/unnecessary.
    Casey
    Apr 2011
    On this same note, I'm in Va. where historical homes sometimes have plastered fireboxes in the fireplaces, to protect the bricks before the days of special firebrick, I understand. Anybody know when this practice was discontinued and how common it was? My old house is from 1860 and I'm considering the same idea. At this point, there is no evidence that the fireboxes were plastered originally. In This Old House, I'd like to see more articles on restoration, instead of renovation.
