    Mar 2011
    NY
    Unhappy toilet w/flush valve flushes too short
    I have had a plumber in 3 times - problem - the flush valve doesn't flush long enough to completely empty the bowel. Even if you hold handle - it still doesn't have the thrust to empty. Bowel is 1938 - the flush valve is about 15 years old - have replaced the blather (leather) - they say it might be the vent on the roof? We do not have any problem anywhere else in house. Other toilet is a tank in the basement. Any suggestions?
    3,201
    Default Re: toilet w/flush valve flushes too short
    Toilets require good air flow in the pipes to work properly. There are a few things to check;
    1- take the toilet out and flip it over. Make sure the toilet itself isn't clogged. (easiest)
    2- While the toilet is off, check out the drain pipe, making sure it isn't clogged. (moderate)
    3- check the vent stack from above the toilet to the sky. Check for clogs. (not hard,but can be a PITA)
    South*East
    1,259
    After time toilets get a build in the inner parts of the bowl that slows the flow of water from the tank to the bowl, making them to have a slow flush. The way to test this is to dump a large bucket of water directly into the bowl at a fast rate. If it flushes then the problem is a build up in the bowl, not a waste or vent problem.
    John
