Thread: We're Stumped
    69
    Default We're Stumped
    I know issues of sewer gas smells have been addressed repeatedly on this forum. I have used much of the advice here to try and figure out where our sewer gas smell is coming from. Last week, I gave up and had a plumber come in to try to diagnose it. He left without telling me anything, although he did locate what appears to be an odd "drain" that has been capped off UNDER the basement bathtub. He said "hmmm, maybe that's leaking". A little back story:
    The house was built in 1980, the last house on the street at the time and remained that way for more than 10 years. It is a tri level house. My husband purchased the house in 1990 with an unfinished basement that had the plumbing stubbed in for a full bath. He hired people to build the walls and set the fixtures to create a full bath down there. He is unsure when the smell started, but is fairly certain it was within a few years of purchasing the home, if not immediately. We have no sewer smell in the cooler months, but when the temperature gets above about 65 degrees, we can count on having it at least once a week, if not more. All of the plumbing, with the exception of the kitchen, runs down the center of the house, dropping pretty much straight down from one floor to the next. Bathroom on top floor, laundry room just below that and basement below that. It all "ends" in the basement closet that is behind the basement bathroom. When the smell does come, it is strongest in the laundry room and the basement closet (although it permeates the entire house at times). We have never smelled it in the upstairs bathroom, and it is never strong in the basement bath. We have smoke tested the vents and got smoke out the roof stack(s). We do, on occasion, have a slow drain problem with the basement bathtub, but this is a recent development and never coincides with the smell. I noticed there is an "s" in the plumbing configuration not too far before it hits the vent. I was thinking it should maybe be a p trap there, but the plumber said no, it shouldn't make any difference. I thought maybe the water was siphoning out of the "s" and leaving us with a dry spot there. We've traced the vent up through the attic and it is all intact. We've been on the roof and the stack isn't blocked. We are on public sewer, not private septic.
    So, first, any ideas at to what that mysterious capped off drain under the bathtub is? Should be noted there are no exposed floor drains anywhere in this basement. Then there's the 64,000.00 question: WHAT is causing the sewer gas smell? The plumber I had here could only give me "maybe it's this, or maybe it's that". We really don't have the budget to have someone in here on a "maybe". Any help at all is greatly appreciated.
    Nashville, TN
    149
    Default Re: We're Stumped
    You have said the basement was finished aftewr the rest of the house was finished. I understand that the plumbing was stubbed out for future.
    If the house drain down the center line to the basement and then the drain line underneath the basement floor is your mainline out of the house to city sewer main. That would mean that your house would HAVE TO SIT on a higher elevation in order for the sewer to drain. In addition to that, all the houses "Down stream" on the city sewer - Where would that sewer gas go? To the top of the sewer line - Your house.
    There should be a cleanout between your house and the city sewer line (required for maintenance and plumbing code). Open that up. Do you see your water draining? Do you smell the sewer from the line?
    I would definately make sure that the vent went all the way from the roof to the basement. And if it was built in 1980, then the main vent should still be a 3" vent thru the roof. Take a garden hose and run water DOWN THE VENT. that water should go ALL THE WAY past the double cleanout to the city sewer line.
    Good Luck. Process of Elimanation.
    Process of elimination. Good luck.
    69
    Thanks for the reply. The vent does go all the way from the roof to the basement. It is exposed both in the laundry room and in the basement itself, as well as in the attic, so that can't be it. I'll locate the clean-out between us and the main line and see what that brings. If I don't see my water running through this, then what? I'm obviously not a plumber, so I'm totally lost beyond what I've already done to try to diagnose this issue. I've exhausted my very limited knowledge. Thanks again!
    69
    I tried to edit the above reply, but I can't seem to get it to go through so I am adding this.
    Was wondering, since we're no longer the last house on the line,(nor were we ever the first house) how would we know for sure if it is sewer gas from the houses (and apartment complexes) down the line from us, what can be done about it if it is from that, and would it be our responsibility or the city's responsibility to correct it? Thanks so much for your input!
