    Mar 2011
    Default Gartbage disposal
    We have a double sided sink and just recently when we run water through the garbage disposal side of the sink, water starts coming up the other side of the sink. If we turn on the garbage disposal, remnants of what was in the garbage disposal start coming up both sides of the sink. What causes that and how can it be fixed?
    Stanwood
    3,120
    Default Re: Gartbage disposal
    Your drain is clogged or partially clogged.
    Take apart the pipes under the sink. Clean them. Pay close attention to the T shaped pipe. They are the usual culprits.
    Mar 2011
    Sounds like that would be the issue, thank you. We'll give it a shot.
