    Question Installing milti outlet strip under kitchen cabinets
    I would like to know how i can replace my standard wall outlets with multi outlet strips being installed right bellow kitchen cabinets? Also, how does this work with existing GFCI's?
    I had seen this suggestion for homeowners whom are about to tile their back splash. I belive this will make the backsplash even more attractive.
    1,384
    Default Re: Installing milti outlet strip under kitchen cabinets
    I have plugmold under my cabinets. It's hooked up to a GFCI breaker, not tapped into a protected outlet, IIRC. It's expensive, but gives a clean look. Plugmold is now made in an angled style which is perhaps better suited to under-cabinet installations.
    Casey I have the original flat type.
    Feb 2011
    Brown county, Ohio
    52
    Are you wanting to keep existing gfcis?
