    Mar 2011
    Default Moving Washer to the Basement
    My wife is thinking of having me move the washer into the basement to increase the the kitchen area. The soil pipe I would need to connect to would be about 8 feet higher than the washer in its' new basement location. My question is, does a conventional washing machine's pump to drain the water have enough force to pump the water up to 8 feet to discharge, or is there some other mechanism I need to include in the move to pump the water up to this height?
    Default Re: Moving Washer to the Basement
    8 feet ?? sounds high. I'm not quite sure the washer pump would be effective going that high --- it might.
    Even so , you would be required cut that line , install a wye and come back a bit to make this a branch and have a "P" trap --- you may also need to vent that small branch as well.
    Are you on a city sewer system? If so you probably have a vertical stack. Perhaps the washer can be relocated near there. This way a washer vented stand pipe can be installed around there.
    Jan 2009
    Needham, MA
    559
    i believe that 6' is the maximum height on what you're talking about. check with your washing machine guide to see, it usually lists how high the pump can go.
    Sep 2009
    florida
    598
    If your machine is a newer model it may work. Im pretty sure you will need to change out the discharge hose for length and possibly add a check valve in the line.This way when the pump stops the dirty water won't drain back into the washer.
    Im with canuk,cut the line and do it the correct way if possible.
    Gizmo
    Hidden Content
    Hidden Content
