    Mar 2011
    Default Refinishing stained woodwork
    We are refinishing a 100 yr old house. The woodwork is wide and detailed, believed to be shellacked. Some of it is in good shape, but some is weathered and cracked. Is it a good idea to use a sanding sponge and scuff down some of the finish and re-coat with a polyurethane or do we have to strip it down completely? What type of polyurethane would you recommend? The wood is dark, so can polyurethane be tinted?
    5,804
    Default Re: Refinishing stained woodwork
    If it is shellac, denatured alcohol will re-liquefy it. Try cleaning the cracked area with alcohol.
    1,180
    Don't use frickin' poly on your woodwork.
    Wash, sand, shellac.
    Casey
    Mar 2011
    Evergreen, CO
    5
    If the original wood has been top-coated with shellac (and you can test that with alcohol as a previous poster mentioned) feel free to use shellac again for your topcoat. It's been around a lot longer than you and I for a reason--it works well in the right setting and interior trim work is certainly one of those areas.
    It sounds like you have some weathered areas that no longer match the color of the original trim. If that is the case, keep reading.
    I usually approach this type of problem like this: Sand the piece as much as required (you'll need to either sand through the finish topcoat, dissolve it, or use a stain capable of being applied on top of the topcoat--gel stains work very well for me in this last instance) and fix any small cracks in the wood with a stainable wood filler. Dust it off and see how far off the color is from the wood you are trying to match. Sometimes you can simply apply one coat of a stain that closely matches the old work at this stage and it's ready for a topcoat. Other times, you need several coats of the stain--be patient. This process can get fairly involved if you are really picky. Usually though, close enough is good enough. I have yet to see anyone examine an entire piece of trim with a magnifying glass and comment on slight color irregularities; this is even less likely with an older home.
    If you are dead set on a polyurethane top coat, keep in mind that several companies offer stain and polyurethane combos that may simplify your job--as with any stain or finishing product, you need to test it on a scrap piece of similar wood to ensure that the old color matches with your new work (perhaps use the back of the trim). This can be a frustrating process, but take your time, let each coat dry, and sooner or later, you'll hit paydirt. I've been turning to water-based poly more often in my own projects--it doesn't smell so bad, dries quickly and I've found it to be very durable.
    Hope that helps.
    "By the time we finish renovating the last room in this house, it will be time to start all over again."
    1,794
    Polyurethanes are not generally compatible with regular shellac. However, if you put a coat of de-waxed shellac on top of the original finish, it can then be finished with polyurethane. "Seal Coat" by Zinsser is a de-waxed shellac.
    Also, shellac can be tinted with universal colorants to impart additional color.
