    Mar 2011
    Default Kitchen wall socket
    The wires coming out of the wall are old and too short,so what do I have to do to replace old receptacle.
    6,115
    Default Re: Kitchen wall socket
    Run new cable or pigtail the wires.
    3,201
    did you tile your backsplash?
    If yes, then add more wire to the existing wire (pigtails as mentioned) Using the proper sized stranded wire will make the job of stuffing everything back in side the box easier.
    Feb 2011
    Brown county, Ohio
    52
    Hello that is good advice from the other two. my only question is when you say the wires are old, are they the cloth covered wires where the insulation value might be an issue? be safe buddy and good luck. greg
