    Mar 2011
    Default sump pump check valve
    I am replacing a PRIMARY sump pump with a combo primary/baCKUP UNIT.
    The old unit has a check valve behind a wall.....
    the new unit has a check valve on the pump.
    questions.... can I leave the old check valve behind the wall as it is?
    Will there be any issues with having two check valves on the same discharge pipe?
    could there be a vacuum created between the 2 check valves that would prohibit the new pump from discharging?
    any advice is much appreciated.
    Mar 2011
    Default Re: sump pump check valve
    the new combo pump I am going to install is a Basement Watchdog model BW4000
    Jan 2009
    Needham, MA
    559
    not a problem at all having two check valves. it won't make any difference at all, leave the old one in place.
