    Jan 2009
    Red face Sewer Inspection by Plumber VS Purchase
    First off I am a pretty handy guy and can do my own plumbing and repairs for my new home, when I get one. I am looking at a home purchase and have not found that house that says home yet.
    I have found several sites that recommend a sewer line inspection using a camera but these are going to be about $300 and up in cost for a plumber to come out and perform. I have found camera setups for about $400-$700 on the internet, yes cheap but they seem pretty decent for the light use I would put them through.
    If I could purchase one for that $400 to $700 and have it on hand for future use, neighbors borrowing it and such would this be a better investment than having a plumber do it. Even if I did get the first home I used it on I feel it might be a better investment than having a plumber do it. If I did not get the home I first made an offer on and used it on the next one then I would end up saving on the second home I use it on.
    I do understand what I need to be looking for and such through having watched a plumber do this on the home I am currently renting as well as the usual knowing what plumbing is from working on my own plumbing. I can also get advice from the internet and such and I do understand that a professional will know more but I can also see what things look like to help me in my home purchase decision.
    You get the idea, what are your thoughts. Should I purchase a sewer camera system for less than $700 and always have it available for my own use or just go the plumber route?
    1,794
    Default Re: Sewer Inspection by Plumber VS Purchase
    A report by a "professional" plumber or sewer inspector may give you more leverage in negotiating the purchase price than your own layman's opinion, if there is a problem.
    If you will be seriously considering several houses, you might do your own inspection first, and if you see something troubling, throwing in the $300 for the professional report. After looking at 3 or 4 houses, it will probably be cheaper than hiring a pro every time, since you'll only need to hire the pro for those with apparent problems.
    But the real questions are, do you want to have to clean up a stinky sewer cam, and will Joe Homeowner trust you not to splatter **** all over his bathroom?
    7,592
    You might see what is available for rent. Rental on such a beast would probably only be $50 - $75 and you'd only have to get it when you suspected a problem OR were looking at homes more than say 30 years old.
    Like you, I like to have the right tool when I need it and would rather purchase something than rent or have to hire out. What I weigh when deciding on a tool purchase vs. rental vs. hiring a pro is the overall tool cost, the likely amount of use it will see, and what would hiring the work done cost.
    Example, your camera costs $700. Say you can rent it for $70 a day, that means you have to use it at least 10 times before it's paid for itself. A pro costs you $350, so that means you'd only have to use it twice. If you think you'd use it more than twice in a year or so, then rental is certainly a better option, leaning towards purchase. If you can get 5 to 8 uses per year out of it, then purchasing makes more sense. Keep in mind that a device like this MAY have other uses, for instance - and this is a spit ball - you could inspect HVAC ducting. If you're an automotive kinda person there are times when you can't see what you're trying to get at under a dash or behind the engine and a camera would be handy. Not saying that this would work with a sewer camera, but if you can find other uses, then the purchase price just got all that much better, didn't it.
    Note - After being down the business end of a sewer pipe, you'd definitely want to clean and sanitize it before trying to send it through an HVAC duct or any other use.
    Just saying ...
    Aug 2009
    Sewage and Garbage collection is a very big problem specially in cities with people moving in,there are numerous newer techniques used to make efficient sewage and garbage dumps, Phoenix plumber did a very good job and we don't have troubles of cleaning
    the tanks, i always trust a recognized company to do my work rather than a single man because their work is guaranteed
