    Mar 2011
    Default tire tracks in lawn
    We had a bunch of trees removed last spring. THIS spring we need to fix the lawn, which has deep tire tracks in it from the trucks driving over it. We're looking to do it ourself and cheaply Any ideas ?
    1,908
    Default Re: tire tracks in lawn
    The ground where the tire tracks are has been compressed. It probably will not grow grass as well as the rest of the lawn if you were to just fill them in with extra soil.
    I'd recommend rototilling that area to fully aerate the soil. Then you can plant seed or sod on top. Do not rototill when the soil is saturated, or you will just make it harder and turn it into bricks. The soil shouldn't be bone dry, either. If you compress a handful of soil and visible water appears (a sheen) it's too wet; if it falls apart it's too dry. You should be able to make a firm clump -- that's a good time to rototill. The rototiller should leave behind soft dirt, almost a foamy consistency.
    I'll leave the actual seed planting detail to one of the other fine folks in the forum.
    Mar 2011
    thank you, Fencepost! Especially for being so clear about how dry the ground should be.
