Thread: mud
    Mar 2011
    Default mud
    I have a mud puddle problem at the bottom of my deck stairs. My down spout ended under the stairs however I have put a flex hose on it to now direct that water to somewhere else in yard. Every time it rains I end up with a huge puddle any suggestions?
    Default Re: mud
    Regrade the area so that water is not directed to and cannot pool at the stairs.
    3,201
    Default Re: mud
    add a hard surface like stone or concrete. Since you step on that location every time you climb the stairs, you remove a teensy amount of soil, and will keep re-creating the low area to collect water. A hard surface will prevent that from happening.
