Results 1 to 1 of 1
    Mar 2011
    Elk Grove, CA
    Default Water Softner install and Drain
    I need to install a water softener, I have room where the main water comes into the house in the garage but there is not drain close. Outside of the garage is the cement drive way. So not sure on methods of draining for a softener? The closes drain is a washing machine drain in the laundry room by the front of the garage which is about 25 ft. plus away and on the other side of a wall. I did not know they had to be drained!
