    145
    Default when to replace garage floor
    I have a crack across my garage floor and water is seeping in during winter thaw and after heavy rain. Is there a repair I can do to fix the leak that would also be a permenant fix.
    desperate times.
    1,522
    Default Re: when to replace garage floor
    if you contact a company such as wise cracks they will be able to give you better advise. there are a few methods they can use such as hydraulic cement or epoxy. just a matter them coming out and evaluating the situation
