    Nov 2009
    19
    Default Washing Machine - Power Shutoff
    I have seen water detection products on the market that will detect water leaks from a washing machine and shut off the water supply. However, are there any detectors that will kill the power to the washing machine? I had a flood from a clogged drain. I needed the power to stop so the pump would not continue.
    Thanks for any tips,
    Stuart
    6,102
    Default Re: Washing Machine - Power Shutoff
    http://www.wayscale.com/flood-stoppa.shtml
    Check the 5th paragraph.
