Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. #11
    6,103
    Default Re: ceiling fan/ wall switch
    Yes, this will work too, whatever the fix, the neutral needs to be coming from the same circuit as the hot feed.
    Neutral is neutral Spruce, the caution is to watch cross linking hots from differnt legs.
  2. #12
    I don't disagree with that, but I'm pretty certain that it's been said that crossing either lead is a bad thing.
    This is why I leave most things up to my 'lectrician.
  3. #13
    6,103
    All neutrals are tied to a common bus, the only time you might have a problem is if you have two seperate supplies in the same building.
