    Mar 2011
    7
    Default World’s toughest drywall/sheetrock
    I have walls made of stone! Nothing seems to cut into sheetrock/drywall and survive.
    A reciprocating saw blade is toothless in about 3”—both metal and wood blades.
    I tried a RotoZip wood bit and it burned up in about ˝ of an inch.
    I even thought a hole saw would work . . . stripped of its teeth almost immediately.
    A hammer (used the wrong one) broke when I swung it at the wall out of frustration.
    (No wonder I always have to drill a hole to hang a picture)
    I swear if there was a nuclear blast near my home, I’d be safe from not only the shockwave but radiation as well!
    I am trying to be deliberate with my demo so not to incur too much additional cost repairing the walls. I am also cutting locations for new outlets and switches but almost nothing cuts into the sheetrock/drywall sufficiently.
    The home was built in 1952 and I still have quite a bit of work to do so I am willing to get the appropriate tool.
    Any thoughts on a tool that might be able to cut my impenetrable walls? What about that MultiMaster thing? Mini-circular saw?
    Thanks!
    Bailey
    Midwest
    179
    Default Re: World’s toughest drywall/sheetrock
    To cut sheetrock or plaster you have to use a tool made for it. A wood bit or blade will not last 5 minutes. A rotozip with a carbide bit for ceramic tile, or a Sawzall blade with carbide grit (not teeth) should work fine.
    "Lead by Example"
    Mar 2011
    7
    Quote Originally Posted by ZZZ View Post
    Heading out to my closest hardware store now!
    Thank you.
    B
    7,602
    You should be able to cut drywall all day long on a single sawzall blade. If you're burning through blades, then I suspect that you have a plaster skim coat over gypsum button board. It is the plaster that's causing your problems, still, you should be able to demo it with a drywall keyhole saw or sawzall with no problems.
    Can you post a picture of the material coming off the wall?
    Aug 2009
    Ladson,SC
    192
    I think Spruse is correct on the plaster base being rock lath.
    As for the plaster it is most likely a gypsun product and sand mixture the sand is what is damaging the blades. This type mixture is like cement.
    Try a Diamond blade on a 4 inch side grinder ( use the thin type blades )and be ready for a lot of dust,use eye protection,dust mask and a space suit if you can find one.
    Mar 2011
    7
    The carbide blade cuts like a dream. Many thanks!
