Results 1 to 10 of 16
Thread: Ceiling Fan ...
    Sep 2007
    5
    Cool Ceiling Fan ...
    Here's one that has me puzzled. I turn on my bathroom fan and nothing happens, i check the power to the fan...good I check the outlet in the fan...good I pull the fan motor out and plug it in a wall outlet and it's good. what could it be????
    Sep 2007
    Long Island, NY
    269
    Default Re: Ceiling Fan ...
    Let go of the blades after you turn it on
    Hidden Content
    ॐשָׁלו
    The deep South
    459
    Can you check the voltage with the fan plugged into it's own outlet AND turned on ? Could possibly have a broken wire with just one strand connected . Just enough to show a voltage , but not carry current . Is the fan blade binding on anything ?
    Sep 2007
    5
    Quote Originally Posted by djohns View Post
    I did not check voltage but I did buy a new fan wired it all correctly and it does not work either
    Sep 2007
    Long Island, NY
    269
    you sure you don't have it wired just for the light?
    Hidden Content
    ॐשָׁלו
    Sep 2007
    5
    there is no light, just the fan
    Sep 2007
    Long Island, NY
    269
    I figured that but sometimes there's wiring for an optional fan and the wiring is a bit different.
    Hidden Content
    ॐשָׁלו
    Ok I'm a little confused... how did you check for power to the fan and check the outlet but did not check for voltage ?
    Is there a GFCI outlet in the room that's tripped ?
    Sep 2007
    5
    with a circiut tester not a voltage meter I know there is power but how much I do not.
    The deep South
    459
    That's another reason to NOT use a circuit tester . You need a decent multi-meter if you'r going to troubleshoot wiring .
    $25.00 will save you a lot of agravation down the road .
