    Mar 2011
    Default Cast Iron or Copper DWV
    Question: as to longevity and durability, is cast iron or copper superior?
    How long, if any, is the galvanized pipe under the concrete slab?
    Do I need to replace the pipe under the concrete slab?
    I have a house in Northern California built in 1956 with 2 stories and 2 bathrooms on the second story. Outside temperatures range from 30-70' F. My DWV, which is original, is a mixture of cast iron (CI) and galvanized steel. Two years ago, my kitchen sink/gutter area of the sewer backed up with leaves and was successfully snaked out. 5 years ago, the master bathroom sink and tub were clogged and successfully snaked. Last year, I had an earthquake retrofit done, which involved replacement of a portion of the kitchen sink vertical drain and the gutter drain was re-routed outside. The vertical galvanized pipe was rusted on the outside AND inside, but flow was possible through both pipes. Both pipes (sink and gutter) were clearly galvanized when they entered the floor/slab/concrete floor. I saw a rusted pipe that looked galvanized inside the slab. I plan to live in this house indefinitely. One contractor recommended copper, as the total cost would be the same for iron, and did not recommend changing the under slab pipe. Another contractor recommended CI, and replacement of the pipe under the slab which was galvanized.
    South*East
    1,208
    Default Re: Cast Iron or Copper DWV
    Both copper and CI DWV come in two grades. No hub CI is std. grade which I have replaced many sections of. Copper for waste should be a minimum of type M. They have what is called DWV, this in my opinion is a bad choice. Why not use PVC? This has become one of the most used DWV piping and is standing up very well.
    John
    6,941
    If the drains are in a walls of rooms you regularly occupy, such as the living room behind the couch, then you'll want to consider cast iron because it has much better sound deadening properties than copper or ABS (black plastic ). If noise is of no concern, then I'd go with ABS or PVC because it's cheaper and easier to work with.
    Mar 2011
    Only copper and iron are code-compliant, i.e. ABS and PVC DWV violate the local building codes.
