Thread: Faucet leaking
    Feb 2011
    Default Faucet leaking
    My Delta faucet is leaking from the handle that rotates for hot and cold and I believe it is leaking to under the sink.
    How do I fix this?
    South*East
    1,208
    Default Re: Faucet leaking
    If this is the faucet you have rebuild it with new stems, seats and springs. Call Delta's 800# and the should send you the parts free of charge. Your handles may not be the same as those on the site, they also come with a round acrylic handle.
    http://www.deltafaucet.com/customers...ml?document=pd
    John
    6,966
    You may also be able to tighten the stem nut a little bit to get a better seal. Remove the handle to get to the nut and give it a bit of a clockwise turn.
    Feb 2011
    Thanks so much!!!!
