    Nov 2008
    55
    Default Energy Recovery Ventilator vs. Humidifier
    I am curious what your (TOH Discussion Board) thoughts are about whether it is better to install Energy Recovery Ventilators or Humidifiers if the home has a extremely low humidity level in the winter (Northeast US).
    My home has steam heating (radiant) and central air conditioning. The humidity levels in the home in the dead of winter is less than 20%. I would like to solve this without having a bunch of standalone small room humidifiers taking up floor space throughout the home --- neither would I want one large floor unit sitting anywhere.
    Installing a humidifier in the Central Air/Con duct work for the winter is really not practical -- since I am not using it in the winter.
    The ideal solution is to install hidden (behind the wall / ceiling) units to deal with the humidity. Which leads me to either ERV's or humidifiers.
    What are your thoughts?
    MN
    455
    Default Re: Energy Recovery Ventilator vs. Humidifier
    My understanding ERV's don't add humidity.
    Nov 2008
    55
    Quote Originally Posted by bsum1 View Post
    I thought so too, but it seems there is a new unit provided by Panasonic which does provide some humidity control.
    This is the write-up from TOH
    http://www.thisoldhouse.com/toh/phot...592459,00.html
    This is the unit on Panasonic's website:
    http://www2.panasonic.com/consumer-e...00000000005702
    MN
    455
    The way I see it ,they don't introduce any more humidity instead allowing the humidty that would be exhausted from the house to help temper the colder air drawn in from outside.
