    Oct 2008
    7
    Default insulating attic access
    I have a cold draft around the pull down stairs leading to the attic. There is a piece of foam insulation set above the stairs when they are folded up, but it isn't doing the job. What can I do to stop the air leak/ Thanks.
    612
    Default Re: insulating attic access
    https://advice.thisoldhouse.com/showthread.php?t=3214
    Listed in this thread are a couple pic's of an insulation box I made to cover our pulldown attic steps. It works pretty well for us.
