    66
    Unhappy Cast Aluminum Standing Mailbox
    I have painted this box twice now.The problem is the aluminum starts I guess you would call oxidation beneath the paint and makes a fine white powder.Does anyone have a solution for some sort of primer coating to prevent the problem so the paint will not peel.Thank You
    1,821
    Default Re: Cast Aluminum Standing Mailbox
    tggringo,
    Aluminum does not accept paint without some preparation. You can etch it with acid or you can get a self-etching primer.
    66
    Thank You Sir.
    Oct 2012
    Itís really great to know the information about self-etching primer, but I think you should know about the quantity of solution you have to add while painting.
    May 2010
    56
    i don't know if this applies to aluminum,but it works for galvanized metal.
    wipe the surface with white vinegar, then wipe down with water or denatured alcohol & let dry. the vinegar is a mild acid & will etch the metal.
    i got this tip from a professional painter friend & never had a problem.
