    Feb 2011
    Default Mobile Home Electrical
    I want to take my mid 70's flourescent ceiling light out of my bathroom and replace it with something more modern.
    Can I just connect the new fixture to the existing wires? I'm wondering if there is a difference in the voltage or anything else I should be aware of?
    Thank You.
    Feb 2011
    Brown county, Ohio
    Default Re: Mobile Home Electrical
    hello there should be no voltage difference, however make sure the box is rated for the weight of the new fixture, and also make see what kind of wires are in the box. if they are aluminum you have to make sure you get wirenuts for alcu or if the wires land on the fixture make sure the fixture is rated for aluminum
