    Feb 2011
    Default Removal of granite counter top
    Hi,
    I am looking for a safe way to remove the existing granite counter top on my L shaped bottom kitchen cabinets. I wish to reuse this counter top on new base cabinets. Does anyone have any suggestions.
    I see the seams where two pieces where joined together, but I am clueless on how to separate them, let alone remove from the cabinet.
    Thanks
    Jeff
    Default Re: Removal of granite counter top
    Jeff,
    If the granite tops were properly installed, they cannot be removed without breaking them. They should have been glues to a plywood substrate with either liquid nails, PL Plremium, or silicone. The joint between the 2 pieces was epoxied together. Unless you use a thin diamond blade, you aren't getting them apart. But then you'll have a missing kerf of granite to deal with.
