    Feb 2011
    Default Best way to cut glass tile
    We have a house built in 1950 and it has 18" x 18" glass tile on the bathroom walls. We removed some of the tiles to repair the walls from where the grout was leaking and to replace the tub with a modern one. Because the new tub is a difference height and the plumbing is now in a different spot, I need to cut the existing tiles so that they can go back onto the wall and be reused. What is the best way to cut the tiles? I'm considering taking them to a glass cutting shop. Thanks.
    3,201
    Default Re: Best way to cut glass tile
    Your idea is an excellent one. That is the same way we cut our glass tiles. We made a youtube videoshowing the process. Make the tiles have a 1/8" joint between the bottom of the tiles and the surface of the tub.
    Be sure to use white glass setting thinset, such as the new stuff from Custom or Laticrete. Where the tub meets the glass tiles, use only 100% silicone to seal that joint.
    Feb 2011
    To start the process, you must use something to go ahead and apply some pressure to the piece of glass that you want to cut. You will do this as you pull the glass cutter on the surface. When you are cutting glass, you want to make sure that the cut is smooth. If you hear nothing, you will know that you are doing a pretty good job. One of the most common things that you will want to avoid is pushing way too hard. Under this scenario, your glass will break or even worse, it will burst. You want to make sure that you have a uniform cut throughout the entire cut. If only one part of the glass is cut well, then you will not achieve a good glass score.
    Feb 2011
    10
    I also checked that on Youtube thats a great video to help uou on the topic, thanks for suggestion
    3,201
    Clink on the link in the above thread #2 to see how its done.
    Feb 2011
    Thanks everyone - I'll check out the video and the thinset.
